cliiff
Nov 25, 2015Explorer
bid_time wrote:
First question, yes 5100 lbs. Max
2. Yes, putting it in the TT will only add a small percentage to tongue weight.
3. No, you can tow up to 100% of your vehicle ratings as long as you don't exceed any. Why would they give you a max rating then tell you you're only supposed to tow at 80% of it?
:D
That's what I thought. Why specify a rating if you then need to use only 80% of it!?
Sounds like that Old Wive's Tale floats around a lot.
