cliiff's avatar
cliiff
Newbie Question on 2016 F150 2.7L SuperCab 3.55 4x4
Hello
Here are the specs on my truck.
2015 F150 4x4 SuperCab
145" wheelbase
2.7L V6 EcoBoost Engine
Elec. 6-speed auto w/tow mod.
Hill-Start Assist, Outboard Mounted Rear Shocks, Trailer Sway Control
Axle Ratio: 3.55
Gross Combined Weight Rating (GCWR): 12,700lbs
GVWR: 6500lbs
Vehicle Curb Weight (weight of truck plus full gas tank) 4937lbs
I weighed it at a weigh station.
First Question:
My user's manual states that: "Do not exceed a trailer weight of 5100 pounds unless the vehicle is equipped with the Heavy Duty Trailer Tow Package or the MAX Trailer Tow Package.
I do NOT have the Heavy Duty Trailer Tow Package or the MAX Trailer Tow Package.
So, does that simply mean that I cannot exceed a loaded trailer weight that exceed 5100 pounds? It obviously seems so.
This seems to be a limitation of a 'bumper-pull'; please verify.
2nd Question.
I did some calculations, assuming that the tongue weight is 10% of the loaded trailer weight.
This made me realized that I can carry more cargo if I put it in the Toy Hauler than in the back of the pickup truck.
Does this make sense?
3rd Question:
I keep reading about an 80% Safety Factor.
Does this apply to the GCWR or the GVWR or both.
Thank you for spending time helping a newbie!
  • First question, yes 5100 lbs. Max
    2. Yes, putting it in the TT will only add a small percentage to tongue weight.
    3. No, you can tow up to 100% of your vehicle ratings as long as you don't exceed any. Why would they give you a max rating then tell you you're only supposed to tow at 80% of it?
  • Does it have any kind towing package at all? Did it come with a hitch installed from the factory?
