2chiefsRus
Apr 23, 2013Explorer
yankeeslover wrote:
makes a lot of sense... so when I leave campground, its ok to have water left in both tanks during travel? and also, when im dumping, do dump stations have water hookup while im dumping so that I can flush it? or do I have to fill up the water holding tank first? thanks again
EDITED - Not sure if it is ok on your set-up or not - I was thinking motorhome when I typed the following)
It is ok to have grey and black water in the tanks during travel but most folks like to dump the tanks just to bring down the weight. Just depends upon your situation. Most dump stations will have at least non-potable water available to flush with but sometimes they don't depending upon the season. If you are staying the campground and plan to dump on the way out, it is a good idea to check it out earlier in your stay.
