mockturtle
Apr 23, 2013Explorer II
yankeeslover wrote:Yes, you can use a five-gallon bucket or you can pump water in from the fresh water tank using the fill pedal. I usually do the latter, provided I have plenty of water on board. But if you're home, it's quicker to just use a bucket.
all good lanerd, thanks... you say when I get the camper home to put several gallons of clean water in the black tank...since this camper has a ccc of only 400 pounds or so, will I be able to travel with water in the black tank? and how do I fill the black tank at home? thru the toilet?
