lanerd
Apr 23, 2013Explorer II
yankeeslover wrote:
all good lanerd, thanks... you say when I get the camper home to put several gallons of clean water in the black tank...since this camper has a ccc of only 400 pounds or so, will I be able to travel with water in the black tank? and how do I fill the black tank at home? thru the toilet?
I'm only talking about three to five gallons of water...approximate 25 to 45 lbs. No big deal. With a 400 lb ccc, I would probably keep it down to about 3 gals. Just enough to slosh around really good inside the tank. This small amount of weight won't be a problem for you.
To fill, as I mentioned, if you have a black tank flush inlet, just connect a hose to it to put in the water. Real easy. If no inlet, then like Pat said or run the hose through the trailer to the toilet.
Ron
