Be sure to note the difference in height for the F-350 and F-250. If you can make the 350 work with your fifth wheel, by all means opt for it. I believe that all of the options are available on the 350 that are available on the 250.
By height, I mean: the tailgate on the 350 is at 59 inches and the bed is at about 38 inches. The 250 is at 56 and 36 respectively. The higher value can put your fiver significantly nose high, especially with one using 15 inch tires. Payload on the 250 is sufficient for many fivers, but if you are thinking of moving to one of the larger, more luxurious versions, the 350 is the way to go. Just be aware of the issues.
You should also be aware that the payload ratings given on the Ford tables that I have seen list those with the gasoline engine, which are significantly different than those with the diesel which is much heavier. To find the diesel payload ratings, you will need to find the Gross Vehicle weight of the vehicle (10,000 for a 250) and subtract the vehicle weight (about 7600 for a diesel truck). Add in your weight and the wife's weight, plus the hitch weight, fuel etc. and you can determine the "book" weight for a fiver pin weight rating. about 1500 pounds for the 250.
Personally, I am looking at the 250, since I have a fiver with only a dry pin weight of 950 pounds, plus it will not accept the height of the 350 without modification.
