1. Is the 1130 enough space for two active adults not to kill each other?
The 1130 (likely referring to a 23-foot trailer) is generally considered spacious enough for two adults, provided you both are comfortable with close quarters and have good communication. Layout matters a lot—if it has a slide-out or a well-designed floor plan, it will feel more open. However, if you’re used to a lot of personal space, it might feel cramped, especially during extended trips. Make sure to spend time in one before committing to ensure it suits your needs.
2. Are there interior mods for baskets or more space for clothes?
Yes, there are many aftermarket solutions for adding storage:
Hanging organizers: Over-the-door or wall-mounted organizers can add space for clothes or small items.
Baskets or bins: Install baskets in cabinets or under seating areas.
Closet mods: Add shelves, hooks, or hanging rods to maximize closet space.
Under-bed storage: Use storage bins or drawers under the bed if your model allows.
3rd-party solutions: Companies like Camping World or RVupgrades offer storage solutions tailored for RVs.
3. Insulating cabinets and outside storage areas for mountain TCing:
Insulating cabinets and storage areas is a great start. Here are additional tips:
Skirt the trailer: Use an RV skirt to block cold air from getting underneath.
Heated water hose: Prevents freezing in cold weather.
Tank heaters: Add heating pads to your freshwater, gray, and black water tanks.
Window insulation: Use thermal curtains or reflective insulation panels on windows.
Vent cushions: Install insulated vent cushions for roof vents.
Space heaters: Use a portable electric heater (safely) to supplement your furnace.
4. Did 2004 include storm/double-pane windows in the all-weather package?
This depends on the manufacturer and specific model. Some 2004 models did offer double-pane windows as part of an all-weather package, but it wasn’t universal. Check your owner’s manual or contact the manufacturer/dealer to confirm. If not, you can add aftermarket window insulation kits.
5. Can I use my OEM Class IV hitch to tow a toad with a hitch extension?
Yes, you can use a Class IV hitch to tow a toad (a towed vehicle), but you’ll need:
A proper tow bar and baseplate for the toad.
A hitch extension if required, but ensure it’s rated for the weight of your toad.
Check your hitch’s weight rating and ensure it matches the combined weight of the toad and any additional gear. Consult your owner’s manual or a professional to confirm compatibility.
6. Bed liner and insulating sheets for the TC bed:
Bed liner: A bed liner is a good start to protect the truck bed.
Insulating sheets: Adding insulating sheets (like foam board or rubber mats) can help with vibration and insulation, but they’re not strictly necessary unless you’re in extreme climates.
2x4 in front of the bed: This is often used as a stopper to prevent the TC from sliding forward during sudden stops. It’s a good safety measure, especially if your bed liner doesn’t have built-in stoppers.
7. Where can I get a pass-through window gasket?
You can find pass-through window gaskets at:
RV parts stores: Camping World, RVupgrades, or etrailer.
Online retailers: Amazon, eBay, or specialty RV parts websites.
Manufacturer or dealer: Contact the manufacturer of your TC or a local dealer for OEM parts.
