Hannibal
Mar 07, 2020Explorer
kellem wrote:
What your missing is how misleading UVW is as it doesn't include Propane tanks, battery, any of the tanks contents, a mounted WDH and every item you stock into trailer.
What I've found on every trailer I've owned is the final weight will be much closer to GVWR and nowhere near the dry weight or UVW.
You got that right! Our advertised 710 lb TW turned into 1,071 lbs within the first couple of trips. It sure tows nice.
The first trailer that comes to mind with the OP’s query is the Winnebago Micro Mini 2106 FBS. Full size appliances and tandem axles in a smaller package.
