jmtandem
Jul 13, 2014Explorer II
Maximum weight fully loaded 7000lbs
tongue weight dry 555
Your tongue weight should be ideally 13 percent of the trailer's weight. Use gross weight and never brochure or dry weights for your calculations. 13 percent of 7000 pounds is 910 pounds. The hitch will weigh anohther 75 or more pounds. And then add all the folks, dogs, bicycles, kayaks, tools, supplies, etc. in the truck and you can reasonably figure your truck's payload needs. The 5.3 and a 3.43 axle is not exactly a towing champ!!!! Maybe that is why some folks tow with more truck than you think is reasonable. Because it works better.
