Nighduckman
Oct 27, 2019Explorer
Newbie towing question
I recently purchased a gas 2019 F250 RWD to tow my 2018 Jayco 24.5 ckts fifth wheel. I am a newbie with heavy-duty trucks. And I have a question about steering with the fifth wheel hooked up. The two-wheel-drive version was the best choice for us because it is 3 inches shorter than the 4x4 F250 and fits under the fiver. And we aren't going anywhere we will need 4x4. The 4x4 would have been too tall and we didn't want to have to raise the trailer any further as the axles were already flipped. We just took it out for its first camping trip and it towed it like the trailer wasn't there. The trailer, loaded, has a pin weight of approximately 1,600 pounds and the truck squatted about 2 inches with the trailer on it. This is a small fifth wheel and well within the trucks specs with its payload rating, per door sticker, of 3,759 lbs and a rear GAWR of 6,340 lbs. I did notice though that the steering felt a little lighter with a tiny bit more play with the trailer on the pin versus the truck driving by itself. It didn't feel out of control or anything just a bit different.
Is that normal and to be expected? I am reluctant to add airbags to address the 2 inches of squat as that would put the trailer too nose high and be bad for the trailer axles. Are there any workarounds to shift some more weight onto the front axle or is the bit of extra play in the wheel nothing to be concerned about? Again, it was steering fine it just felt slightly different loaded than unloaded. Thanks!
