SoundGuy
Jan 16, 2018Explorer
stevevalwa wrote:
What other thoughts do you have besides the obvious I need to upgrade my tow vehicle? Will do so in time.
Unfortunately you have a significant problem now, not "in time". Take a look at my own trailer towing calculations here and here. This is towing a 19' trailer averaging 4800 lbs loaded & ready to camp, average gross tongue weight ~ 620 lbs, with a 5.3L V8 Silverado, GVWR 7000 lbs, GCWR 15,000 lbs ... yet I'm almost completely out of payload capacity. :E Your situation is SO much worse, your Sequoia isn't even remotely close to being suitable for towing a trailer of this size. FWIW, these calculations aren't any different than what one can do manually with a calculator, the worksheet just does it for you. If you'd like an .xls copy PM me with an email addy that accepts attachments and I'll forward a copy you can plug your own numbers into. Believe it though, you won't like the results. ;)
