BenK
Jan 17, 2018Explorer
IMHO, best to use the OEM’s info...instead of a non-OEM source...which has a copy/data-entry mistake potential. I’ve found too many issues from 2nd/3rd party sources
Toyota 2008 Sequia brochure
Only missing info seems to be GAWR’s
As most have advised...load up ready to go RV’ing and weigh it axle by axle
Then do the simple math....generic formula to figure : GCWR >= TV + Trailer+ stuff (actual weights)
RGAWR is needed to check if enough “R” vs what it will be asked to handle
Most half ton’s RGAWR are in the +4K range. Higher class TV’s are in the +6K range. Most weight goes on the rear axle...just take a side view most TV’’’s.....mid point between front axles is at the read edge of the drivers door
Decide if you, the OP, believes in the ratings system or not
If yes, gather the specifications and follow them
If not, then academic this thread...
If just looking for the “sure you can”....then you the OP have it, but know only one person is responsible for the setup and that is the driver....none of us advisers have any skin in your game
