bgum
Sep 05, 2020Explorer
Do not plug it into any house plug that "looks" like your trailer plug. Use only normal wall plugs that are 120 volts and you should not try to run your trailer Air conditioner on that. If in doubt make sure the plug is NOT 220 volts. When plugged into house plug you can operate all 120 volt items except A C but not all at the same time. Microwave or water heater one at time. As you learn more you will learn what can be run at the same time. This will get you started.
