Jimster's avatar
Jimster
Newbie Waste Valve Question
During the three week-long trips we’ve taken with our new Arctic Fox 811, I frequently found up to a cup of liquid in the waste collector pipe when I opened the sewer termination cap. Is it normal to have some seepage past the gray or black water waste valves after the TC has been on the road for a while? The dealer told me not to worry about a bit of seepage; if there’s a problem, I want to fix it before the warranty runs out.
  • A bit of vaseline applied to the blade and the slot it moves in will solve it if you can get your hand up in there...
  • I have had that issue through the years but corrected it by replacing the valve. Have the dealer replace the valve they are cheap.
    I don't like to have to deal with that type problem, so I installed an elbow and a twist on waste valve on the outside. If the primary valve starts leaking I find out without getting splashed when I remove the outside cap. I think it was $16 on ebay a couple years ago.
  • It can depend on where the black tank is located - if the tank is located forward (such as some Lance models) and a drain pipe running toward the back - then liquid can remain in the length of drain pipe after the valve is closed.
    Make sure the camper is tilted toward the sewer receptacle when draining AND wait a few minutes AFTER closing the drain valve. This will allow any remaining liquid in the drain pipe to drain out and not accumulate at the cap.
  • Possibly typical, but not proper behavior.
    Our valves would leak a teaspoon of waste between dumping. Not a big problem. I replaced them because I have experienced about ten gallons coming out when the cover was removed, and KNOW I wanted to avoid that again.
    Valves are not very expensive. Amazon sells just the seals.
    Matt B
  • It could be perfectly normal if there is plumbing between the valves and cap that hasn't fully drained (usually due to the angle of the truck during dumping). Not every camper has a straight shot from valve to the outlet.
  • I'd try opening and closing firmly a few times each time you dump and see if it fixes the issue.
  • How long between dumps.........how long to accumulate this 'cup' of liquids???
    Could be seepage
    Could just be residue from dumping and then capping line off vs letting it drain/dry after closing dump valve
  • No. Some seepage up to a point but I would consider a cup is excessive. Especially new.
    Could try running clear water down drain working the valve, but dont jam it home. Either valve gasket not sealing or debris in sealing area keeping it from fully seating.
  • No way I would consider that normal.
