wanderingaimles
Jul 20, 2019Explorer
3HappyCamperz wrote:wanderingaimlessly wrote:
Maybe this will be of some help to you,,,
***Link Removed***
Thanks for this. Yes, I did run into this thread when I was doing my research, but I'm still confused!
Look at the part about the transmission cooler located in that drivers side opening. That cooler is a great indicator of whether or not your unit is capable of the heavier weights.
Also your GCWR should give you an indication. 5000 tow cap will require the GCWR to be near 11000 pounds.
44,066 PostsLatest Activity: Apr 16, 2026
