rowekmr
Mar 11, 2017Explorer
Great suggestion!
I like this simplified formula for calculating max trailer weight. I think it is much easier than the traditional longer formulas. My only question is this formula I believe would apply to loaded weight not empty weight of trailer. If my math is correct it assumes a tongue weight of approx. 14.28 % of total trailer weight so I wouldn't want to use this figure (7x) for unloaded weight unless I planned on not carrying much.
I don't have an Escalade but I don't see why the OP couldn't find a moderate sized trailer to tow safely. I have towed with 1/2 tons and they can tow well within their design limits the trick is following equations like this to find something within your weight limits.
APT wrote:
A mid 6000's dry weight TT will be close to that 7800 pound tow rating.
Practically, half ton SUVs will run out of payload when carrying a family and towing and RV under payload. Check your as equipped payload per the tire and loading sticker. Note what your vehicle has where mine says 2051.
Subtract the weight of the people who will be traveling inside and multiply by 7 to get a reasonable dry weight target.
44,056 PostsLatest Activity: Jan 12, 2020
