mapdog wrote:
I'm not trying to tow anybodies trailer from this forum. What about the trailer I put the link for?
EMPTY, that trailer all by it's self will use HALF of your 1100 lb cargo capacity.
You stated that you are planning to "full time" out of it..
I would have to say it could haul it empty BUT, with full timing you WILL be taking a lot of "stuff" with you..
I suspect that you will find yourself in a bind looking for a more capable tow vehicle in a hurry once you load up all of your possessions you wish to take with you..
I would recommend taking a look at some USED trucks which have a higher cargo rating.. You could most likely get into a used 2011 SD with a 6.2 gas engine for less than the cost of a new Ram Eco Diesel..
2011 and up F250 SDs have a pretty high cargo rating, I have a 2013 F250 4x2 super cab short bed with 3.73 gears and a cargo rating of 3415 lbs..
In spite of what some folks like to think about it being OK to go overweight, it isn't them that has to deal with break downs, repairs, premature wear and tear that will happen once you go over the ratings.. YOU will have to deal with it.
It isn't them that will have to deal with the feeling that the combination is questionable, it is YOU that has to deal with it.
That trailer is over 28 ft, starts out using up half of your vehicles cargo and when loaded will most certainly exceed your vehicles cargo and possibly one of the axle ratings.
Move on to a different smaller and lighter trailer or ditch the vehicle and buy a older used vehicle with more cargo..
You WILL thank yourself in the end and not hate a bad decision..
