Kayteg1
Jul 21, 2018Explorer II
I have not seen truck stop on West coast who would not have DEF pumps.
Trucks have fuel tanks on both sides, so the stops have 2 pumps connected to the same meter.
Meaning even if you have fuel on 1 side DEF on the other, you can still fill it at the same pad.
A bit annoying. I used truck stops for fueling my sedan (before they switched to B20), who has fueling pipe on passenger side and I have to pull the hose form driver side pump to start the meter, lay the hose on the ground and then go to passenger side hose.
What I learned in the mean time is that DEF is having limited shelf live.
My sedan has DEF tank in the trunk, design for 10,000 miles fills at oil change, so I can't fill it from the pump, but being sceptic how old is DEF sitting on store floor, I am getting a can to fill it up with DEF and truck station and then fill up my sedan at home.
Truck stops have high volume sales, so you know DEF is fresh.
