BFL13
Dec 24, 2020Explorer II
noteven wrote:time2roll wrote:noteven wrote:Only trouble is most 7-pin connectors have OEM #14 wire and a 40 amp fuse. Good chance that 40 amp DC-DC will pull 50/60 amps and open the fuse resulting in no charge. I recommend 20 amp DC-DC if using the OEM 7-pin connection.
I have a question:
If I have 2 x 100ah LiFeO4 house batteries with a charge rate spec of "1C" sitting at 20% after a rainy few days in the forest, how long does it take to charge these batteries via the truck engine when I start up and drive away, using the "7-way" connection?
I figure a 40amp DC-DC charger recharges them fully in 4 to 4-1/2 hours.
I didn't word that right - how long will the standard 7 way pin system take to recharge Li batteries?
Same time as "ordinary" batteries. Say you get 10 amps from the 7-pin (mine will do more like 6 amps after the first few minutes at 15 to 10 ) then your "ordinary" batteries will accept that many amps easy, so no different from Li batts.
Li batts have a higher amps acceptance rate, but that doesn't count when they are not being offered that many.
