noteven wrote:
but generally the little blue "charge wire" is not capable of carrying the significant amperage required to charge batteries in less than days...
Yep, the factory charge line is typically only 12AWG wire.
I did this upgrade for higher amp charging a few years ago.Bert the Welder wrote:
I am looking at using a DC-DC charger to charge batteries from the engine alternator.
This is what I'm going to use- toddbExplorerI found the brake thing to be true on my '15 350. I use an victron orion 12|12 9a dc-dc charger. It suits my needs for a small charge to keep up with the compressor fridge and utilizing the factory truck and camper wiring.
- Bert_the_WelderExplorer IISo lets push our luck that this one is granted entry to this thread too.....
Mr. Wizard: I'll not put you through further questions from a pea brain. But would ask if, since you have obvious knowledge in this area, you've seen a video or website that has a good, straight forward explanation on the how's, what's and why's of truck to TC charging systems, suitable for the rank beginner?
Much appreciated! - Bert_the_WelderExplorer IIOK.... Thanks Mr. Wizard. I have a long reply typed out with questions, but keep getting formatting complaints. So I'm going to give up before I send the laptop out the window......
I just really need to give up ever understanding this stuff.....
Time for a sedative......
*Edit: Well, at least this one got through...... - Buzzcut1Nomad II
Agree, but check the wire going from your engine back to the camper plug. If it's way undersized, as is often the case, nothing else matters until that gets an upgrade. You can't blow a golf ball through a garden hose..... :)
That's the reasoning behind why lance recommends skipping using the trucks wiring harness and trailer plug and running 8 gage wires directly from the battery (positive and negative) through a 40 breaker and into the Lance bed plug at the front of the bed. Bigger pipe shorter run. - Bert_the_WelderExplorer II
riah wrote:
I think its more related to the truck electronics than to the batteries, as charging the camper batteries off the truck is an issue with lead acid batteries as well! We had similar issue with charging our typical auto batteries (lead acid) we were using for our TC solar system. We too thought we should be able to charge them off the SD F350 as it had a second alternator, but it didn't seem to work very well. So now we are looking at the DC-DC charger option so that when we get our LiFePO4 replacement batteries we will be able to keep them charged when it's overcast and we are driving, as that seems to be a missed opportunity for us currently without it.
That's a lesson I gleaned from folks here. It's all a system. Look at each section, start to finish and can each component along the way handle what the previous one is throwing at it.
And I also learned that camper electrical is better left to someone else. The tough part is finding that someone else that is trustworthy.... - billtexExplorer IIThe “delay” is interrupted when you step on the brake pedal. A fail-safe Ford built into the charge system.
- theoldwizard1Explorer II
A second alternator is really only useful when your vehicle has very heavy loads (additional lighting, electric powered hydraulic pumps, etc).
A DC to DC charger is the only way to fully recharge a RV house battery bank. And they do not need extra heavy duty wire ! - theoldwizard1Explorer II
Thanks. I'll look him up and try to find the vid's. It certainly seems like having something like the DC2DC is needed for the "new" type batt's.
First, I worked for Ford designing Powertrain Control Systems for over 30 years until 2007, so I DO KNOW what I am talking about. Yes, I am sure things have changed since then and different manufacturers do things a bit different.
Second, there are really two issues here. Is the alternator capable of putting out sufficient voltage and current to charge a RV "house battery bank" (1 or more batteries wired for 12V nominal) AND are voltages directly from the alternator "optimal" for recharging a house battery bank.
Almost all vehicles built after about 2000 have some type of "smart charging" system. Theses systems are designed to only replace the amount of energy used to start the vehicle and not let addition loads cause the starting battery to discharge. In simple terms, immediately after starting, the voltage at the starting battery will be about 14V. Within about 5-10 minutes, that voltage will drop done to about 13.2V at the starting battery. Even with the heaviest gauge wire you can install, you are not going to get more than about 13.2V at your house battery bank ! This is not sufficient to recharge a house bank that is below 80% SOC !!
Different battery chemistries require different voltages for optimal and complete charging. Flooded lead acid is different than AGM is different than LiFePO4.
A DC to DC charger, install close to your RV's battery bank, will BOOST the incoming voltage and apply the correct voltage to your battery bank !
44,053 PostsLatest Activity: Jan 06, 2022
