FishOnOne wrote:
Cummins12V98 wrote:
spoon059 wrote:
I'm still excited for the current gen Ram!
I do believe that the transmission is the current "weak link" on the HD Ram, keeping them from increasing power output by too much. Honestly though, with the amount of weight that these trucks can move, I don't really see too many more gains to be had in towing ability. I mean, you can haul over 16 TONS with a freaking pickup truck. That is insane to me!
When you get into payload ratings, we have to be getting close to the maximum weight per inch of tread here. The fact that Ford can get over 7,000 lbs of rear axle rating on a dually is pretty awesome!
I guess I'm looking for better reliability, more gears and better fuel economy. That's just me though.
"I do believe that the transmission is the current "weak link" on the HD Ram"
What are you talking about??? I towed 28-29K combined with my 11 HO Dually with NO issues with over 1/2 of that towing. Pic is at 65K with at least 50K on the fluid.
I tow 33K combined with my 15 RAM Dually with the Aisin trans. True Medium Duty used in many other applications.
"The fact that Ford can get over 7,000 lbs of rear axle rating on a dually is pretty awesome!
Are you talking carrying capacity? Or RAWR? I would assume Carrying. I would also assume F450?
I'm confused... Sometimes the 68rfe is very capable (even though you installed a after market oil pan) to do the job, and the next time (pending the sales pitch) you have to have a true medium duty transmission to do the job. So which is it?
Please advise,
fish
If you have read any of my posts both the 68RFE and AISIN are great trans. Towing in the heavier weight weights and higher HP/TQ ratings the AISIN is preferred.
I installed an aftermarket pan for more fluid capacity and it did keep the trans cooler than other stock temp reports. The AISIN is amazing with the temps in the low to mid 170's towing 33K combined even on 14 percent grades in June thru the Rockies.
AISIN is a true MD trans as it is used by several other manufacturers.
