Adam R wrote:
Let's be clear once again. This was 20 years ago before any of us knew what a DPF was and hot rodding options were fairly limited back then on an all mechanical pump. That truck only smoked when I wanted it to and for the record, I was and am still nothing like that jackwad. The level of obnoxiousness on a scale of 1-10 was a 12, possibly a 13. He was gang-banger material. I spent a couple of thousand dollars for that pump and the injectors to be re-worked and it came back boost compensated with even more power potential.
He probably spent a couple thousand on that sound system.
Gang banger, how would you know?
