Ron_Gratz
Apr 17, 2014Explorer
FJP800 wrote:I believe your Armada has a receiver TW rating of 900#.
I have a 2014 Nissan Armada with a towing capacity of 9,000 lbs and I am considering buying a Rockweood Windjammer 3008W which has a Base/Dry weight of 7038 lbs. My concern is the ability of the Armada to pull the camper, when fully loaded with supplies, especially if when we visit the west coast. I believe the rule of thumb is add 1,500 lbs to the dry weight to be on the safe side when considering the weight of a camper which would be 8,538 lbs. Please let me know what you think.. Especially if you have an Armada or a vehicle with the same towing capacity. would the 3008W be too much for my car the handle? Thank you
If so, a maximum allowable TW of 900# and a typical TW% of 13% means the maximum loaded trailer weight would be limited to 900/0.13 = about 6900#.
If you wish to assume the TT's dry weight should be 1500# less than the maximum allowable loaded weight,
you should be looking for a TV with a dry weight of 5400# or less.
If you use a WDH to return the TV's front axle load to its unhitched value, the vertical load imposed on the TV by the TT will be about 80% of the tongue weight.
That means a TW of 900# would cause about 720# to be added to the TV.
You need to find your TV's TIRE AND LOADING INFORMATION sticker and note the "should not exceed" value.
Then calculate your best estimate of weight of occupants, any options added after delivery, cargo to be carried in/on the TV, and about 100# for a WDH.
Subtract this combined weight from the "should not exceed" value.
The reminder is the amount of payload capacity left for trailer-induced vertical load.
With a 900# TW, the remainder should not be less than 720#.
Ron
