TPUC wrote:
I have a 2012 Nissan Titan Pro 4X 4 door same drive train. Rated to tow 9100. I tow a 29 footer dry weight of 5700 I figure pushing 7000 loaded. Tows great. The Armada has an Independent rear axel and I am not 100% sure how stiff it is. My live axel and springs are a bit on the soft side. Motor wise you could tow about anything as long as you can keep gas in it. I also added an external trannie cooler.
That's what I told the OP- 5,000pounds +/-. Anything over that amount dry will not tow well.
