Old-Biscuit
Sep 11, 2020Explorer III
Boon Docker wrote:BEagen wrote:
2oldman: The two 6v were in series, but one was inadvertently reversed. I assume that created a reverse polarity situation. Sorry, I don't know how to post a diagram.
carringb: Wiring diagram shows a 40 amp fuse between the battery and converter but I can't find it. Believe me, I have looked and looked...
Old-Biscuit: I agree. But, cant find anything like that. No 30 amp fuses on the DC Dist Fuse Panel; just 15s and 20s.
I need to find the in-line fuse/breaker somehow. Thanks for all your comments and insights.
Follow the battery cable (likely the negative) from the battery to where it goes under the trailer look for small (approx 1" x 1.5") circuit breaker (box). Should be 2-3 ft from the battery, it may or may not have a reset button.
Except -----
Fuse will be on POS cable
On the a-frame and will be a small 2 stud box...reset is typically on side of the DC Circuit Breaker
Example: DC Circuit Breaker
Example: Reverse Polarity fuses on DC Dist Fuse Panel----40A
44,065 PostsLatest Activity: Apr 14, 2026
