Boon_Docker
Sep 12, 2020Explorer III
Gdetrailer wrote:
Example: DC Circuit Breaker
One should note that the breaker shown in photo IS a "self reseting" or "auto reseting" breaker (IE no reset button to push) and is typical breaker used by RV manufacturers.
HOWEVER, in order to get this breaker to auto reset, one MUST REMOVE BOTH POWER SOURCES (IE converter must be powered down AND the battery source must be disconnected from the circuit). Once all power has been removed from the circuit then and only then will the breaker reset.
Do that first before throwing parts at this.
Some misinformation above here.
What is the black button for in the image if it is an auto reset breaker?
Auto reset breakers are automatic reset, no need to power down anything.
44,065 PostsLatest Activity: Apr 14, 2026
