Old-Biscuit
Sep 12, 2020Explorer III
Boon Docker wrote:Gdetrailer wrote:
Example: DC Circuit Breaker
One should note that the breaker shown in photo IS a "self reseting" or "auto reseting" breaker (IE no reset button to push) and is typical breaker used by RV manufacturers.
HOWEVER, in order to get this breaker to auto reset, one MUST REMOVE BOTH POWER SOURCES (IE converter must be powered down AND the battery source must be disconnected from the circuit). Once all power has been removed from the circuit then and only then will the breaker reset.
Do that first before throwing parts at this.
Some misinformation above here.
What is the black button for in the image if it is an auto reset breaker?
Auto reset breakers are automatic reset, no need to power down anything.
Correct^^^^^
Small button on end is the RESET button for that CB
AUTO Reset.....resets automatically ---no need to power down/power up, no disconnecting anything thing
As to POS or NEG location of fuse or CB
Fuse goes in series with the load, to protect the power supply if the load shorts out.
Fuse/CB can be on NEG but best practice is POS so 'power supply' is shut off/
NEG side leaves DC on POS which can accidentally be grounded
44,065 PostsLatest Activity: Apr 14, 2026
