lanerd
Jan 06, 2014Explorer II
You didn't say, but I have to assume that you reset the GFCI outlet...correct?
Are you sure nothing else is not working?? Have you gone around and checked all other electrical items?
As newman mentioned...two different electrical sources. The fan and light will be on two different 12vdc fuses and the outlet on a 120 vac circuit breaker.
If you have an inverter, check on the side of it for push button type of circuit breakers...it's very common for one of these to trip and I bet you have other outlets that are non-op as well.
As for the light, I suspect the bulb is out. The fan can be a fuse that you're overlooking. Anything other than these possibilities will require someone with rv electrical knowledge to track the problem down.
Good luck
Ron
Good luck
Ron
44,027 PostsLatest Activity: Mar 12, 2025
