TucsonJim
Jan 06, 2014Explorer II
Please let us know if the other 120Volt outlets are working in the rig. If not, when you reversed the cables, you most likely blew the inverter fuse. It's actually in the circuit to protect the electronics if you reverse polarity like you did. My inverter fuse is very hard to find. You need to pull the inverter out of the cabinet in order to access it.
44,027 PostsLatest Activity: Mar 12, 2025
