mgirardo
Aug 17, 2017Explorer
We had a water leak in our Rockwood Roo HTT. Water came in from the bottom of one of the storage compartments that wasn't caulked from the factory. After replacing the wood and foam, I bolted 3 2x4s to act as I beams where the floor was replaced. Our HTT was already very low on CCC, so went with wood instead of steel. It helped a little, but the floor was still soft. Once the vacuum of the initial install is broken, the floor will be soft or spongy.
Our Roo's floor had 12 inch centers. I think if I had run a bolt through the aluminum sub-frame into the 2x4s, the floor may have had a little more rigidity. I didn't think about it until after I put the vinyl floor back down and I didn't want to have to redo it again.
-Michael
-Michael
44,056 PostsLatest Activity: Jan 12, 2020
