beemerphile1
Aug 17, 2017Explorer
Matts6foot8 wrote:
...1/4" plywood panels sandwiched on 1-1/2 foam. Towards the rear the water,grey,and black tanks support the floor.....
Terrible design, your best bet is to install a plywood floor on top of the existing floor and then whichever floor covering you prefer.
Another possibility would be to install hardwood tongue and groove flooring. T&G laminate flooring will not add sufficient rigidity.
Either way you will need to compensate for the additional thickness and don't forget about the increased weight.
44,056 PostsLatest Activity: Jan 12, 2020
