johnnylawless's avatar
Aug 11, 2014
No grey tank?
1983 Man-O-War 15' Travel Trailer
My kitchen sink and shower appear to bypass a tank and they pipe in right before the sewage drain.
Is the correct/legal? I suppose, if the exit is plugged, it will backup into the black tank.
It's had some work done, so I'm not sure if it ever had one or if this is a home plumbing job. All the plumbing hangs pretty low to the ground, I'm scared I'm going to bust it on a speed bump.
  • Yea, he gave me a blue tote tank with the trailer. I thought that was for the sewage or something, and that I had a separate grey tank. Does grey and black water both go into the tote tank?
    EDIT: I guess I'm not sure where the grey ONLY hookup is.....
  • I have had a couple old trailers and that is how it was done. You use to connect a length of hose to it somewhere and run it out on the ground. Now as far as being legal or not that will depend on the state you live in. I live in Idaho and last time I checked you could run grey water onto the ground. You will have to look it up and also in most campgrounds they dont like it to be done.
  • Thats how it used to be done. Get yourself a blue tote tank to handle gray water. My 73 Terry was the same way. Can no longer dump on the ground so you do need a solution.
  • It should be plumbed into a grey water tank for sure. Someone did a slop job repair. Pipe hangin low is not factory work. Sorry. This is where having a used RV checked over prior to purchase would have saved you on this.
  • Sounds like you got a park model that was designed to stay hooked to a sewer line in a fixed setting. Designed to travel for transport to a site only.
  • Maybe on that rig the grey water just ran to the ground they use to do that. Best to post a picture so people can see what you are talking about.
