OBX-GL's avatar
OBX-GL
Explorer II
Apr 24, 2014
No Heat - Regulator ?
Trailer is in the driveway, so we are not freezing.
Had the heat on today while getting things ready, got really toasty. I left the trailer and when i returned the heat was off. After a lot of trouble shooting found i had lost gas in the cook top which i had running earlier. The left right switch/regulator for the tanks is showing red even though the tanks are full. I disconnected the trailer side of the regulator and turned the tank on, no hissing, gas is not passing through. Is my problem solved, the regulator has failed closed ? Would it fail while running ? Any thoughts ?
