Boband4
Nov 06, 2016Explorer
You could do a quick check by flipping the tow vehicle around and putting jumper cables from the tv to the trailer battery. This would tell you if your circuit is interupted by a breaker or disconnect. If evrything lights up you will know you have continuity and can start the research of a bad battery or converter.
44,026 PostsLatest Activity: Mar 03, 2025
