- jmcgsdExplorer
hogcard wrote:
Took it to dealer. Unhooked everything and opened the door to show him nothing works and well you guessed it. All worked fine. He said he would still have them trace everything.
Boy does that sound familiar! Years ago I had a hot water issue on my Lance. The temp of the water was inconsistent. Took it to the dealer a bunch of times. They replaced check valves, etc. but the problem would not go away. One day I noticed that the controls on the outside shower had not been properly closed. Shut them all the way off and the problem disappeared. - hogcardExplorerTook it to dealer. Unhooked everything and opened the door to show him nothing works and well you guessed it. All worked fine. He said he would still have them trace everything.
- 700gExplorerJust fixed the same problem on mine yesterday. Mine was the auto reset circuit breaker near the battery. It would let voltage thru it but when I would turn on a light, voltage would drop to 3 volts per my meter. I tore open the old breaker and it was completely rusted inside.....
- jc1843ExplorerA cheap 12 volt test light is a great tool to find problems. Start at the battery-- and work back-! Also each powered light/accessory needs two sources-- 12 volts-- AND a good ground. Missing either one, and it will not work.
- colliehaulerExplorer IIIIf your jack works your battery is fine. Do you have a battery disconnect switch?
- hogcardExplorerBattery did test 13+ but they did not test under load. However the power jack works just fine. It is a separate connection to battery. Taking to dealer tomorrow as I found another warranty issue this weekend anyway.
- ksg5000Explorer IIHad something similar .. checked the fuses etc and everything appeared OK .. when I got home I discovered that one of the battery wires hidden under shrink wrap had pulled loose of the connector to the battery lug.
- naturistNomad IIAh, no 12 volt suggests that the place to look starts at the battery. I know you said "battery is fine," and I don't mean to insult your intelligence, but I had a battery go bad on me that tested "fine" with the volt meter. It showed 13+ volts, but it delivered no amps. I took it to the auto-parts store where they put it on a load tester, and although it showed 13+ volts for them too, as soon as they applied a load, the voltage fell to zero. Take the load off, and it was back to 13+ volts. So unless you've already had it tested under load, you might consider doing that. Auto parts places will do it for you for free, as they expect you'll buy a battery should it be bad.
From there, it is a matter of following the wires with a volt meter in hand. Could be switches, or fuses, or circuit breakers. Could also be a wire some rodent munched on. - LynnmorExplorer III had two of the cheap "red key" type of battery switches go bad in a very short time. Check that the switch is working.
- jimw606ExplorerI had the same problem, when I first got my R-Vision. There was a circuit breaker underneath the front in the 12v hot line. I also found a Key switch in the front LH compartment.
44,068 PostsLatest Activity: Jun 21, 2026
