Navy_E-8's avatar
Navy_E-8
No power from Battery
1st post - 1st question. 2nd trip with newest tt. I have power to both 120 and 12v systems when plugged into shore power or connected to the truck but it must be running. I have no power when just connected to battery. Battery is tested good. No blown fuses that I can find. Any suggestions
  • I saw that on you-tube and on here also. I am not saying there is not a reset button but I could not find it. I have two sets of a two prong device with wires going to them. Was told that a tiny reset button was on one going to the trailer. I did not dis-connect the wires - Is that necessary to set the reset button???
  • Follow the red wire from the battery, it usually connects under the trailer to a circuit breaker. There should be a button to reset it.
  • No battery cutoff switch anywhere. If there is I cannot find it.
  • Battery cut off switch somewhere?
    Anyway, welcome to the Forum...members with much more knowledgeable than me will certainly solve this one for you....
