Riley7970 wrote:
The plugs that are listed as gfci have no reset switch, no power to ac or refrigerator
GFCI outlets are wired so if the first one trips, the whole circuit dies. An overloaded circuit will not ordinarily trip a GFCI.
Even though you said you replaced all the breakers, I'm fairly certain your problem is in the breaker panel/converter somewhere. The air conditioner is a purely AC powered appliance, so your open is in the AC circuit.
If your lights don't work, that's a DC problem. AC meets DC in the converter. Sounds as if you blew the internal fuse inside the converter.
