stupendous_man's avatar
Mar 02, 2022
No Power to 7-Way Plug?
Hi all, electrical problem’s got me stumped. I’m no expert so I figured I’d ask some.
I have a 2000 Lance truck camper not receiving alternator power from my 2009 Silverado 3500. The truck has the heavy duty trailering package, so the plug is attached to the rear bumper. I went into the fuse box under the hood and attached the external power wire, adding a fuse.
As I understand, the truck-side 7-way plug has ground on the bottom left and 12V power on the top right. When I check these with a multimeter, I get 0V. I also have a bundle of wires in the middle of the truck for an additional 7-way.
The running lights, turn signals, and brakes all work with the rear 7-way plug. It appears the previous owner replaced and rewired the camper-side plug.
I don’t have a lot of experience with RV’s, so let me know if any of this needs clarification. What could be going wrong here?
Thanks!
  • wnjj's avatar
    wnjj
    Explorer II
    When you say, “adding a fuse”, did you add an inline fuse or did you populate the fuse in the fuse box that powers up stud #1? Did you make sure there is power where you connected the wire?
  • Replace the 7 pin....and work your way back to the front..It could be something so simple like a ground wire.....keep at it. You will find the fail. 7 pin plugs go bad all the time..when did you use it last? How did you know you were not getting power to the RV?...I'm stummped here...External charging wire? WHY? SO...you have 2x 7 pin connectors? My truck does....but you say your using the rear plug on the rear bumber? This is confusing...if I try to help we all need more detailed info. The TC power is hooked up where? Do you have a battery switch? Connected to the fire wall? For a second plug?
    When you have two seperate systems that supply power to an RV it is common that the rear bummper plug will be hot while the rig is running but like mine it is split... When you turn off the rig, the bateries are seperated from the RV. I have a 7 pin on the front interior of my truck bed. I have a 7 pin at the hitch. The wiring at the bed connection is beefed up from the factory because I made that tweek to help make the batteries get more power when we travel.. I hope this makes sence..I was running dual 36 Interstates with a 100 watt sollar. All I needed. I am not going to rule this out...but have your alt checked..It is the prosses of elimitation...keep working you will find it!!!
