westend
May 21, 2015Explorer
kkimkozi28 wrote:
OK. That will be the next step. Unfortunately I'm at work all day. I'll check that out tonight. And what happens if it comes back to have no power?
You may have a tripped breaker in the battery's positive (+) lead. It is located close to the tongue. I would think that if the converter is supplying 12V power, though, it should supply enough current to operate the fridge.
If you had a momentary flash of lights from the fridge, you may have a short somewhere and the fuses may have blown again. Your new meter will verify that the fuses are good or bad.
