VictoriaChan
Jan 15, 2018Explorer
enblethen wrote:
Mae sure it is the thermostat by connecting the two wires together. the furnace should start immediately and then produce heat in 15-20 seconds. Then separate the wires and furnace should go into cool down and shut off.
Check to see if the circuit breaker on furnace is not tripped. Small red or white button to reset.
Uses multimeter to test wires on thermostat, get nothing.
There is on/off button on heater, it's on. Anything else I need to check?
Thanks
44,025 PostsLatest Activity: Feb 18, 2025
