Monkeyman_and_L
Nov 10, 2017Explorer
Too smart a thermostat?
Freeze warning in our area tonight, and they ain't kidding. Hadn't dumped fresh tank and needed to purge lines. So much easier on the class A.
Then I decide to keep coach warm so I can follow up tomorrow with final winterizing stuff. Air purge and pink stuff into drains and tanks.
Set thermostat for both zones to 60, dial to heat pump. Notice the furnace kicked on. Hmmm, not what I wanted, so I remove the furnace fuse.
Come out later to do a couple more quick items, notice coach interior at 37 degrees, both zones. Started troubleshooting. Notice that after I reset the power on the thermostat and set up temperature demand, the unit flashed between heat pump and furnace.
Reinstalled furnace fuse, opened propane tank, cycled twice because of air in the line and timeout. Furnace now heating.
So, is it just smart enough to know it can't jump the temp 23 degrees to insist on the furnace being active?
This heating system has me baffled. Gotta sort it out.
Anyone else?
Anyone else?
