cargodog's avatar
cargodog
EcoBee Smart Si Wifi Thermostat
Hey all,
New to the site as a member, but a frequent reader of many of the posts here.
I'm one of those that likes to tinker and tweak my trailer. And sometimes some of the mods lean more towards just my gadgety side vs practicality. So, some here may scoff at what I'm trying to do, but even if you don't see the practicality of it, hopefully you can still assist with the execution of it :)
A few year ago I upgraded from my standard analog Duo Therm thermostat to a Honeywell digital thermostat. Love it. Works like a charm and far more sensitive in maintaining a desired temperature. For anyone who hasn't done the mod, can't recommend it highly enough.
I'm currently working on taking the mod another step by installing an EcoBee Smart Si wifi thermostat. My trailer is parked at a campground and I have 24/7 free wifi. So, my summer 2016 projects are to make my trailer 'smarter' (again not necessarily practical, but more because I'd like to lol). I figured I would start with the thermostat, which would allow me to cool the trailer (or heat) prior to my arrival. So perhaps when I'm an hour away, can have the system get the trailer to the desired temperature.
The obvious problem is that the smart tstats run off of a 24v system and the Dometic air conditions are 12vdc controlled. At first, I thought that would be the end of the project, but have since come across a gentleman who did install one using 12v source from the Dometic and an EcoBee Smart Si. He claims (and is noted on the Ecobee site in a testimonial) that the 12vdc is enough juice to run the Ecobee.
My question is a) has anyone here tried this and b) I saw one homemade diagram (in the digital upgrade mod) showing the power coming from the Dometic as +7.5v vs +12v? I wont be at my trailer for a week to be able to take my meter and check for myself. But am curious is that is correct or not?
The second followup would be, if infact it WAS +7.5v vs 12v and I had to get 12v to the tstat (either via a common wire, or even external transformer) what effects would there be of sending a 12v vs 7.5v signal? Suppose worst case scenerio is blowing the control box which would not be good. But, curious none the less. I've yet to see a wiring diagram diagram anywhere showing 7.5v coming out of the aircon unit.
PS here is the link to the project page" ***Link Removed***
Thanks
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,417 PostsLatest Activity: Sep 03, 2026
