Grit_dog
Apr 04, 2021Trailblazer
Kayteg1 wrote:
Evidently Ford engineers concluded the truck doesn't need them.
Bear in mind since 2017 Superduties are 500 lb lighter than older models, so with the same payload, the rear axle is having close to 500lb less load.
My 2017 F350 dually was hauling camper (scaled at 6300 lb at 1 time) without any modifications.
And 4 years later you still believe this. And even if the “350lbs saved in Al body and new frame , with some of the savings reinvested in heavier components “
did result in a little theoretical weight savings, it wouldn’t significantly affect payload capacity over the rear axle.
