mrbreeze_az's avatar
mrbreeze_az
No room for second battery
My new TT came with a single group 24 battery and no room to install a bracket for a second battery. My solution is a moving dolly with 2 group 29 battery boxes mounted, cable connectors for quick connection and a 3 way marine switch to select and cut off. Does anyone have a similar setup or another system? Thanks
  • I dont hsve pics. Its in storage. The battery box is located behind the propane tanks but recessed between the frame rails. No room to mount a box or a frame on the rails between the tanks and the front of the trailer. The weight distribution mounts are on the frames and cant be moved forward or the chains won't hang straight up and down. Ill get pics this weekend.
  • Can you post a picture of the tongue area? Or is oem battery in a compartment?
  • I've never seen a trailer that doesn't have enough room for two batteries when there is enough for one battery.
    Any pictures?
