Old-Biscuit
Oct 21, 2020Explorer III
Mrjasenstuart wrote:
Thank you for the information and advice. I will try putting more of a demand on the propane and remove and clean the burner. It is helpful to know that there is a regulator that needs reset. I couldn’t find any gas turn off as others did on their models. By clean the burner, do you mean blow it out more thoroughly once it is removed, or actually wash in water or some other cleaner? Thanks again. I hope this fixes my problem.
Orifice...soak in alcohol then air dry **No poking anything thru it/No high pressure air ---it can damage the metered hole
Burner...small bottle brush then blow out with air
thermocouple...emery cloth to lightly scrub just enough to remove any soot/carbon
44,068 PostsLatest Activity: Jun 21, 2026
