kansanforlife's avatar
Jun 17, 2014
norcold 6062
Have a 1993 jayco eagle Norcold 6062 fridge , works fine on 110 but very tempermantal on propane. Ican work it from outside and the electronic ignition lights it but when the ei stops so does the flame. I have had it running on propane before and it cooled great but a lot of fiddling with it to get it to work.Have taken apart and cleaned burner.
  • The Ignition Module (outside compartment above power module) provides the 12v DC power to OPEN gas valve, supplies the power to ignition electrode to light main flame AND holds the gas valve open when main flame is sensed.
    The ignition electrode is also the flame sensor......if main flame is not sensed then ignition module will remove power from gas valve closing it.
    Electrode needs to be directly over burner slots
    Gap between electrode and burner should be 1/8" to 3/16"
    Electrode must be engulfed by main flame
    You can check for continuity of electrode.....
    Fridge OFF
    Unplug electrode wire at ignition module (check for loose/corroded connection)
    One probe of meter on electrode
    Other probe of meter on bracket (ground source)
    Any readings and electrode is shorting to ground....replace
    Here is a service manual that covers your model........LINK
