- kansanforlifeExplorerWell time to give up on it. Isee on craigslist theres somebody in I think springfield mo will put a cooling unit on for 375 dollars.
- HeisenbergExplorerOld-Biscuit has a good statement about the rear circulation. Spider Webs, mud daubers, dust, and the possibility of a circulation fan which has quit.
- kansanforlifeExplorerStrange. Been o n 14 and 70 all day . had to leave for an hour, came back its on 14 and 43.
- 1. RV refer Freezers should be BELOW 10 degrees
2. The refer should be below 40 degrees
Is the refer in a slide room?
Pressure is WRONG. 11.5 is the pressure you need. 10.5 will cause cooling problems. Doug - kansanforlifeExplorerThermostat set at coldest setting. On normal only 26% humidty. Gas valve working properly. had flame checked and pressure at 10.5. This 3 weks ago at one time was down to I think -3 fr. and 28 box for maybe a day. been having quite a time with this thing.
- Old-BiscuitExplorer IIIThermostat turned all the way up?
Storage/high humidity switch position.......normal or high humidity?
Main flame burning...strong/steady blue flame? That used gas valve still working?
Good air circulation/flow across backside of fridge...no obstructions, no dead air spaces?
Have you tried it back on AC power? - kansanforlifeExplorer20 hrs on propane.its 102 degrees here
- wolfe10ExplorerHow long has it been running. Takes at least 24 hours to get down to temp.
BTW, 14 in the freezer is hot, as, of course is 70 in the refrigerator.
38,774 PostsLatest Activity: Apr 26, 2026
