My 1995 coachman trk camper has a Norcold 6052 single door fridge and the problem is it works fine on AC set on auto and will continue if switched to gas on the eyebrow board, but is will not work at ...
You need a new upper board and / or check the connector from the board to the harness,the pins might be loose. The board is relatively cheap at Dinosaur Electronics.
