Old-Biscuit
Jun 26, 2019Explorer III
First off....
Need to use a voltmeter and check that you have 120VAC at that terminal block
(Black is HOT, White is NEUTRAL---should show 120 volts between the two)
No 120VAC....check if the Circuit Breaker for Fridge in Main AC Panel is tripped.
Turn it OFF then BACK ON
YES 120VAC....then check the 3A fuse inside that BIG YELLOW fuse holder on the black wire
LP ...you got it to light and stay on.
How long did you let it run?
Fridge when starting up will take several HOURS to cool down. First the freezer THEN the food compartment
Furnace blasting out hot air anytime you run gas??
Is thermostat OFF?
Is thermostat OFF?
44,068 PostsLatest Activity: Jun 10, 2026
