bbcac
May 21, 2017Explorer
Norcold N611 five blinking error on fridge panel
I have a Norcold N611 refrigerator in my RV. I just bought it and it has an issue. When I first turned on the fridge it cooled well for several days. For no obvious reason, it went into a lock out mode (5 blinks). If I turned it off and on, it works fine again. The freezer makes ice cubes even on low and the fridge keeps everything nice and cold. After a few days it quits working. Once this happens a few times, the fridge goes will not work at all until I do the reset procedure on it. I have to jumper pin 2 to ground and it resets. At this point it works fine again and the cycle continues. It behaves the same on AC or gas. It works for 1-7 days each time. I have replaced the power board and everything behaves exactly the same. Could it be the thermistor? I checked venting and it looks clear now but there was a bunch of leaves on the roof and vent that I had to remove. I took the vent cover off the roof and the path looks clear.
